Old 07-22-2019   #1
klork
Default getting rid of secondary injectors?
So I am going to be running my engine off of megasquirt. I have a set of 65 lb injectors and it will be easier to run 8 injectors then 16. I know I could figure out a way to run 16 but I am not sure I see the need too. If I run a catch can for the pcv so no oil fumes are going through the intake I shouldn't have an issue with carbon building up on the back side of the valves correct? I am just doing some thinking and wanting to run it past some other people.
klork is offline   Reply With Quote
Old 07-22-2019   #2
RussMcB
Default Re: getting rid of secondary injectors?
Are you running the MS3-Pro? If yes, it runs 16 injectors. Maybe you could just contact DIY Tune and get a LT-5 base map from them?
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 07-22-2019   #3
klork
running ms3x. A step below pro but might have the same capability. I will have to compare the spec sheets.
Old 07-22-2019   #4
RussMcB
I can't offer any helpful technical details, but I lent my '91 ZR-1 to DIY Tune and they installed a MS3-Pro and tuned it. I've been driving with it often for a few years. It still has functional secondaries.
Old 07-22-2019   #5
klork
I am just not sure i see the need for secondary injectors if my primaries are more then large enough for the engine and I eliminate any oil residue with a catch can so the valves dont carbon up. Why add extra cost and complexity?
Old 07-22-2019   #6
RussMcB
What about when you toss the keys to the young valet parker? :-)
Old 08-01-2019   #7
rkreigh
it will be easier to run 16 injectors. if you don't, you may have some issues with the back sides of the valves getting cruddy
I don't think you will find it hard to stage injectors
on my tune it runs both injectors at anything above 1%$ tps and throttle response is excellent.
95 390 LPE ZR1 (505 rwhp)
Old 08-01-2019   #8
How stock is ur motor? The reason they used secondaries was to control PW at idle, which is small, and yet have enough injector for top end. 65# injectors will be difficult to control for idle unless MS does something else like vary fuel pressure.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
