#11 |
![]() Join Date: Feb 2011
Found out from Marc that the 94-95 AC components changed to metrics and therefore everything changed from prior years.
#12 | |
![]() Join Date: Sep 2018
Yup, that seems to be the case.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
#13 |
I'm pretty sure the 94-95 R134a AC parts hunt is finally over.
Here's the list: Compressor - Jerry's Gaskets Condenser - Corvette Central Accumulator/Dryer - Corvette Central Accumulator Hose - Zip Corvette Evaporator Hose - eBay Evaporator orifice - Corvette Central Evaporator - Old Air Products Compressor Hose - The Parts Place High Pressure Switch - GM Parts Giant High Pressure Temperature Control Switch - eBay Hard to find some of these and not all were correctly assembled (3 tries from different vendors for the compressor hose) , but the vendors in the list above had the correct parts.
#14 |
![]() Join Date: Mar 2014
How did the AC hose assembly come packed from the Parts Place?
Was there any packing material protecting the hoses and did it come in a flat long box or a more square box? thanks for any info.....
#15 | |
More of a squarish box, paper packing material, hoses folded, not kinked, metal tubes perfect. AND it was built correctly!
#16 |
I was not so lucky.....same box....no packing materials at all....and imperfections in the tubing....and yes it was built correctly.....you received a good one.....mine was not so good....I sent it back.
