Old 05-09-2019   #1
S.hafsmo
S.hafsmo's Avatar
Default Vehicle speed sensor problems
I've recently taken the car out of winter storage, and my first long trip has revealed some issues with the vehicle speed sensor. Intermittent loss of speedometer to begin with, but now it's mostly out all the time. This causes SES- and Service Ride Control lights, also loss of secondaries.
I'll get under the car today to check the sensor/connectors/wires, but are there any other known issues with this system?
I'm guessing the sensor is a MY 90 spesific, no longer available, and the later version uses a different signal?
- '90 ZR-1
Old 05-09-2019   #2
S.hafsmo
S.hafsmo's Avatar
Default Re: Vehicle speed sensor problems
Removed the sensor, and got a bit surprised by it being below the oil level in the transmission (messy business). Just held a rag in the hole while visually inspecting the sensor. Looked fine.
The vss was working before I tinkered with it, but not after. Came back after a few miles.
An interesting thing worth noting, is that it starts to function if I put a bit of load on the engine. High gear/high speed. Could it be that the twisting motion of the engine moves the wiring loom in such a way that a poor connection gets temporarily fixed? I haven't had time to check the loom yet.
- '90 ZR-1
Old 05-09-2019   #3
Demps
Demps's Avatar
Good info here:
http://www.zr1.net/forum/showthread....light=Vss+gear
Ted
Old 05-13-2019   #4
S.hafsmo
S.hafsmo's Avatar
Thanks Demps, I've read that one. At least my gear is still in place. Wondering if I tugged the harness when I had the tranny out. Does the harness go straight to the ECM?
It seems the vss function is not load related, but speed. Above 50mph it usually pops back into life. Can I assume it generates higher voltage at higher speed?
Sent from my SM-T719 using ZR-1 Net Registry mobile app
- '90 ZR-1
Old 05-13-2019   #5
FYI, the later 91-95 VSS should work fine, you just need to change the connector on the harness..
Old 05-15-2019   #6
S.hafsmo
S.hafsmo's Avatar
Thanks Jeff. Are these still available? If the rear of the car is on ramps, should the sensor be above oil level?
- '90 ZR-1
Old 06-02-2019   #7
S.hafsmo
S.hafsmo's Avatar
Did some testing today, but I'm still left puzzled. There's no clip on the gear on these, yes?
VSS gives voltage depending on rotating speed, but as I don't have any comparison, I don't know how what voltage it should give at low speeds. Seems slightly unstable at slow rotational speed. 1.5V AC / 480 RPM.
Checked continuity of the cable by jumping the end terminal and measuring at the sensor connector. Yellow/purple cable. Shows 0 Ohm.
Still no result after re-connecting. IMG_20190602_112158.jpegIMG_20190602_113450.jpegIMG_20190602_113500.jpegIMG_20190602_113517.jpegIMG_20190602_112302.jpeg
- '90 ZR-1
Old 06-02-2019   #8
S.hafsmo
S.hafsmo's Avatar
Don't know why the pics show twise. Uploaded through the app.
Edit, seems fine now.
- '90 ZR-1
Old 06-02-2019   #9
randy ransome
randy ransome's Avatar
I have a 95 ZR-1, the speedometer and odometer quit working. I bought a new VSS at NAPA Friday. It's made in America and appears to have the same markings as the original. Installed it Friday afternoon and drove to a car show. About 150 miles round trip. It worked Great all the way and I won #1 place in my class.
File Type: png Screen Shot 2019-06-02 at 10.52.39 AM.png (491.7 KB, 33 views)
Old 06-02-2019   #10
HAWAIIZR-1's Avatar
Hey Randy,
Congratulations!!
Do you mind sharing the Napa part # that works for a 95? When I researched it at RockAuto it shows a few different part numbers. I’m in the US right now and will get a Napa part if so. Thanks!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
