Old 03-26-2019   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Thank You.......
To confirm that it is in fact the primary pump try pulling the fuse to the secondary pump and see if it will start.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-26-2019   #12
Rumblin70SS396
Thank you again Jagdpanzer, I will try that tomorrow evening and post results
Rumblin70SS396 is offline   Reply With Quote
Old 03-28-2019   #13
Rumblin70SS396
Anyone know where the fuse is located for the second fuel pump? I looked on the passenger side of the dash and didn’t see anything that was really clear..
Old 03-29-2019   #14
HAWAIIZR-1's Avatar
If my memory serves me correctly, it is actually under the dash on the right passenger side. You will have to remove the kick panel and get under the dash to see it. If you’re a bigger person you might have to remove the seat to get under there.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 03-29-2019   #15
HAWAIIZR-1's Avatar
Here you go:
https://www.corvetteforum.com/forums...ump-fuses.html
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 03-30-2019   #16
Rumblin70SS396
I have to be an idiot.......I mentioned the secondary pump and I really need the fuse for the primary pump since the car shuts off after being warm. After I got the dash apart I reread my post......ugh!
Old 03-30-2019   #17
Rumblin70SS396
If it needs fuel pumps (again) where is the best place to get them?
Old 03-30-2019   #18
Ccmano
Jerry’s Gaskets has this on his site... I’ve use the Preformace Electric pumps from RockAuto.com with good result several times.
H
Jerrys Gaskets ZR-1 Corvette LT5 Parts, Gaskets & Seals www.jerrysgaskets.com
Unfortunately, new senders w/pumps are no longer available. This leaves us with the only the option to repair the unit. More often than not, it’s only the fuel pumps that have failed. Both pumps are identical and are available from several different manufacturers.
GM #25163473 (ACDelco #EP381) (fits suburban w/454 engine) w/o strainer, (Rock Auto) $57.79
BWD #P36
Neihoff #P36
AIrtex #E3240 (E3940) has been reported to have different elec connector
Performance Electric #P240KC (Rock Auto) $18.70
GMB #5301042 (Rock Auto) $20.79
Delphi #FE0039 (Rock Auto) #45.99
Carter #P74037 Rock Auto) $24.99
Carter #P74074 (Cross ref to GM #25163473) Rock Auto $33.89
Carter #P74167 Cross ref to GM #25163473) Rock Auto $33.89
Bosch #69225 Rock Auto) $53.79
Denso #951-5016 (exact fit verified)
Denso #952-0057 Fuel Pump Strainer only
I would recommend the Denso unit, Amazon & WalMart @ $57.04. Does not come with new filter socks
Old 03-31-2019   #19
Rumblin70SS396
Default Thank You.......
Wow awesome! Thanks so much as I will be purchasing Denso units as soon as I can confirm it’s the pump.
Old 03-31-2019   #20
Rumblin70SS396
Found it, looks like a blown fuse Boys......will charge the battery and try and start tomorrow..
