Old 03-21-2019   #1
Rumblin70SS396
Default Thank You.......
Hello all,
Just wanted to say thank you to all on the forum. After 4 years I finally have my car running smoothly and a good portion of it is because of the people here. I asked questions but did a lot of searching as well. Thanks again, I still have a ways to go but at least I am heading in the right direction.
Rumblin70SS396 is offline   Reply With Quote
Old 03-21-2019   #2
Ccmano
Ccmano's Avatar
Default Re: Thank You.......
That’s what is all about! Keeping the Legend alive and helping great folks like you. If you haven’t already, hook up with some of the Wazoo ZR-1 group in your area. (MD, DE, VA, PA) A great bunch to get to know and learn from.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-22-2019   #3
Peaven
Peaven's Avatar
Congrats OP...that's what's so special about ownership of the KOTH, the community takes care of each other. Doug Johnson was right.
SteveB
'94 ABZ Lucky #13-SOLD
Peaven is offline   Reply With Quote
Old 03-22-2019   #4
So happy hear that you were able to sort things out.
Old 03-22-2019   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
He says it well!
Makes us happy to hear of the progress made!
Most helpful bunch of folks that you will find anywhere.
We kind of like these cars you might say, and by extension, their owners.
Marty
Old 03-22-2019   #6
32valvesftw
I too have had mine 4 years and it is running better than ever. If you have not done so consider changing your plugs, mine seemed OK, but changing them made a world of difference.
Old 03-23-2019   #7
USAZR1
USAZR1's Avatar
Glad to hear you're back tinkering with Ole#952, Tony.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 03-25-2019   #8
Rumblin70SS396
Thanks again all! I believe the Wazoo group did reach out to me to help, but due to my work schedule and no trailer I couldn’t get the car there.
That being said, it didn’t last long, let it warm up yesterday and went for a ride, only to die in the neighborhood. Seemed fuel related where it would start and immediately shut off. I let it cool down and was able to fire it back up and get it to the house.
Upon getting home, got a code 54, low voltage to fuel pump. Where is the best place to start with that one?
Tony
Old 03-25-2019   #9
Jagdpanzer
Jagdpanzer's Avatar
Sounds like it could be your primary fuel pump. When starting cold the ECM turns on both fuel pumps. Then cuts off the secondary pump when the engine coolant temperature reaches 176 F.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-26-2019   #10
Rumblin70SS396
Thank you Jagdpanzer. Sadly I replaced the pumps a couple years ago and the car sat due to an intake leak. I imagine the pump may be bad with the old gas. Didn’t know if there was anything else I should check before replacing the pumps.
Tony
