Old 03-21-2019   #111
Default Re: ECM And Ignition Module Availability/ replacement
Fantastic! Jerry, the Vimeo link is not working. Would luv to see it.
H
Graham has it up on Facebook. I revised the link above to show the video there.
Old 03-21-2019   #112
Ccmano
Have you tried posting it to YouTube? I saw it on Graham’s Facebook post but the quality was poor. Good work can’t waut to see the final product.
H
Old 03-21-2019   #113
jss06c6
Stellar stuff guys!! Thanks for the persistence and innovation!
Old 03-21-2019   #114
BlackZR1
BlackZR1's Avatar
Excellent!! And a dramatic presentation!! Congrats!!
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 03-22-2019   #115
Saw the video on the registry’s Facebook page.
What are the next steps?
Old 03-22-2019   #116
Congratz on a significant milestone! Packaging/cooling, duration, and temperature cycling tests to follow, I presume. But, this is one of the most significant breakthroughs for our cars in some time! This ONE item may have a truly significant impact on market value of our cars too! "Keep the Legend Alive!"
Old 03-22-2019   #117
grahambehan
There are many steps to complete in the process of validating the hardware and software going forward. The video shows what actually is a pretty significant stress test for the circuits simulating a grounded plug wire. Next up will be connecting all coils and wires and debugging the code for the auto dwell function, followed by a more comprehensive test cycle with the simulator. Then connecting to a factory harness and ecu to test the est functionality. There will, no doubt, be issues found in the debugging process, but progress is being made in pretty significant steps right now.
Graham
grahambehan is offline   Reply With Quote
Old 03-22-2019   #118
This is the prototype DIS Module circuit board & billet case, that is controlling the spark firing the ignition coils in the still photo and video shown in post #106 above. It interesting to see the spark at a single coil, during the demo from idle to 8,000 rpm.
Old 03-22-2019   #119
alexco
Graham, I was wondering if you happen to know a part number for the mating connectors (male) for the two connectors (one 4 wire and one 2 wire) that plug into the coil pack? I would like to make a pig tail that plugs into the stock harness. Any help would be appreciated. thanks.
Alexco
alexco is offline   Reply With Quote
Old 03-22-2019   #120
Jerry,
Will the final units be potted or conformal coated? Since it will live under the hood
