Old 01-02-2019   #11
Great White
Great White's Avatar
Default Re: LTPWS Light
Black
Great White is offline   Reply With Quote
Old 01-02-2019   #12
Originally Posted by Great White View Post
Black
It’s a Mystery..... why some work why other don’t .....,
Old 01-02-2019   #13
Great White
I can't even be sure if my car had the original sensors though. The wheels have been changed by a prior owner, and the body has 154k on it. I doubt the original sensors survived that many tire changes.
Old 01-03-2019   #14
dredgeguy
dredgeguy's Avatar
I asked Marc Haibeck about this issue and now I understand the confusion. There are 2 lights--who knew? I see the light at start up and then it goes out but did not know there is another light that must have been pulled by a PO. Marc explains as follows:
There are two bulbs. One for the LTPWS control system and one that goes on when a tire is detected as having low pressure. The system error light has been removed. The low pressure light never goes on when driving because there are no sensors to report a low tire pressure. When the ignition is turned on normally both lights flash for the lamp test. In your car only the low pressure lamp goes on when the ignition is turned on. A detailed description of the LTPWS system is located here:
http://www.zr1specialist.com/HAT%20W...g%20system.htm
Learn something new everyday!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 02-12-2019   #15
Joelbbvette
Joelbbvette's Avatar
My 90 has the full system and it works. Tires under 25 and I got a low tire light. My "specialness" is that when I get near cell towers I get a Service LTPWS light. Goes off after a few miles. Anyone else have that issue?
Joel
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 02-12-2019   #16
Reichert
Joel
I also have a 90 with a full working system, and the LTPWS light comes on intermittently as well. I never correlated that with proximity to cell towers .. I'll pay attention next time! I thought I just had a sensor on the fritz.
-Stephen 1990 #2288
-Stephen
1990 #2288
Reichert is offline   Reply With Quote
Old 02-13-2019   #17
I never noticed that on my 91 but it makes sense as they do send a signal to the receiver.
