Old 10-04-2018   #11
Default Re: LT5 info
Originally Posted by klork View Post
So these engines came with twin 24 lb injectors per cylinder?
They're rated at 21# w the stock fuel pressure.
Old 10-07-2018   #12
klork
Does anyone know the weight of a fully dressed lt5?
klork is offline   Reply With Quote
Old 10-08-2018   #13
Weight, as crated by GM - 739 lbs
Crate size - 43"L x 36"W x 39"H
Note: includes Bellhousing, Dual Mass Flywheel & complete clutch
GM Crate for "crate" only weight guess-timate
Old 10-08-2018   #14
Mystic ZR-1
Mystic ZR-1's Avatar
Like to have a few crates like that stuffed
away in my basement!
Old 10-08-2018   #15
BigJohn
BigJohn's Avatar
If it's just the crate; I will help you get it in your basement.
If it's engine and crate; we may need some planks and my 5500.
Old 10-08-2018   #16
Mystic ZR-1
For some reason, I expected that response
from you... 😄
Old 10-09-2018   #17
What year Volvo wagon,size wise think of a Big block Chevy.
Old 10-10-2018   #18
klork
1990 Volvo 745. Ford 4.6 dohc engines fit and they are about 2 inches wider so I shouldn't have too much of an issue getting it to fit.
