Old 09-25-2018   #1
rush91
Default Squeaking coming from left side wheel
I've noticed the last few times I have driven my Z, a squeaking noise coming from behind me. It sounds like from the left side of the car. It almost sounds like a shock squeaking....It was happening on uneven pavement, but now its happing on every drive. I haven't had time to put her on jacks to take a look, I'm hoping its not something major. It happens in both backing up and regular driving. You can't hear it from inside the car, but if my window is down you can hear it....
Old 09-25-2018   #2
dredgeguy
dredgeguy's Avatar
Default Re: Squeaking coming from left side wheel
Left wheel bearing
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-25-2018   #3
rush91
Originally Posted by dredgeguy View Post
Left wheel bearing
That is what it sounds like. Should I leave the car parked until it can be fixed, or is it driveable?
Old 09-25-2018   #4
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-25-2018   #5
Squeaking would make me suspect rubber bushings more than wheel bearings.
Spray some water on dogbone, struct bushings and drive listening for the squeaking noise.
Old 09-26-2018   #6
Left wheel bearing
SEE...... New Rear Wheel Bearings and Half Shaft U-Joints
You will find a New Trick to easily remove the Half Shafts
I would expect squeaking to be more associated with brake pads or calipers.
A rumble I would expect associated with wheel bearings.
Old 09-26-2018   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Yes, fully agree, brakes, including emergency brake would be first places to check.
Marty
Old 09-26-2018   #8
ALLTHECAMS
ALLTHECAMS's Avatar
Yes check brakes first. Make sure you pads are in good condition and pins , etc are well lubricated. If that isn't it check half shaft u-joints.
Sent from my XT1710-02 using Tapatalk
1991 ZR-1 #520 Arctic White/Gray
ALLTHECAMS is offline   Reply With Quote
Old 09-26-2018   #9
rush91
Originally Posted by DRM500RUBYZR-1 View Post
[/COLOR]
[/COLOR]
Marty
I never thought about the brakes. I don't get the squeak when applying the brakes, just when the car is moving. No rumble to speak of, just a slight squeak....... But my check ABS light on, and it won't go off.
Old 06-17-2019   #10
rush91
So I found the problem.....when taking off the tires for new ones, the strap fell out in 2 pieces. No telling how long this had been flopping around in there.
