09-14-2018 | #1 |
Running on 7 Cylinders
My 1990 was running great until today. Note: The car has 31K miles and I drive it about 1500 per year. When I started it up I could detect a miss. As I drove it the miss became more apparent. All of the gauges read normal and there were no warning lights. At idle it made a helluva racket, especially with the AC on. I stopped at a local shop and the mechanic said I was getting spark to all 8, so probably not a coil. He thought a fuel injector had gone bad. Sounds reasonable I suppose. A couple of questions for you seasoned Z folks:
1) Can a clogged injector be cleaned? 2) Do they all have to be replaced? (I am going to try to find out if they were changed by the previous owner). 3) Why would the AC cause more rattle? 4) If not a fuel injector issue, then what are some other probables? 5) Would it make sense to check compression and spark plugs? Thanks for your thoughts and recommendations. |
09-14-2018 | #2 |
Re: Running on 7 Cylinders
If it's one cylinder and spark is good, your mechanic is probably spot on, especially with very little driving.. do have the original injectors? If so, ethanol is probably part of the problem..
Sent from my XT1585 using ZR-1 Net Registry mobile app |
09-14-2018 | #3 | |
09-14-2018 | #4 |
In light of the fact it’s a 1990 model year good chance it’s a bad fuel injector. Here are instructions how to check the coil resistance on the injectors without having to remove the plenum:
http://www.zr1specialist.com/HAT%20W...in%20Place.pdf Sent from my iPhone using ZR-1 Net Registry
09-14-2018 | #5 | |
09-14-2018 | #6 |
Thanks Jerry, for the additional information!
09-14-2018 | #7 |
Great article, thanks Phil. I will try it out.
09-14-2018 | #8 |
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
