08-15-2018 | #41 |
Re: Building a beast...doing a 391
Nice work by Dr. Greekenstein.
08-22-2018 | #42 |
Hi Evan! Longtime no speak GORGEOUS SteelBlue! That was always my fave color on the Z's!
Good luck with the build and I will be subscribed to this thread watching your progress -Carlos
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B] [SIZE="1"][SIZE="2"]1992 ZR-1 #483 [COLOR="DarkRed"]Dark Red Metallic[/COLOR] [U][B]Mods[/B][/U] -Jeal headers -Stock exhaust with X-pipe -4.30 Gears -Corey Henderson tune -375 RWHP[/SIZE][/SIZE] |
08-24-2018 | #43 |
Motor is assembled and going in:
Pete also started tearing down the old engine, and turns out it wasn't a head gasket. Said it it looked like it swallowed a worm clamp. His guess is someone left one sitting somewhere when doing maintenance at some point in the past and it got sucked in and probably sat in the intake manifold, then finally worked it's way into #6 cylinder. Cracked the liner, bent the valves and damaged one of the cams. Would certainly explain why it wasn't running well.
Evan
2024 Z06 SOLD - 1991 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
09-04-2018 | #44 |
Motor is back in the car and running:
But of course nothing goes smoothly, Pete said the voltage was dropping the longer the car runs, so time for a new alternator. Also waiting on shocks to come back from being machined to fit coil overs. Few other minor issues to fix once all that's done, but it's getting closer. Pete also fixed the fit of the exhaust: Previous: Fixed:
Evan
09-04-2018 | #45 |
You are getting her dialed in.
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
09-04-2018 | #46 |
Dr. Greekenstein does good work.
09-04-2018 | #47 |
Lookin gorgeous! And your car will be ready just in time for the Texas Mile Shootout happening Oct. 26-28 in Victoria TX
https://www.theusmileracing.com/dates-and-schedules/
09-20-2018 | #48 |
No new pics but a few updates:
So things are moving along well, and I can see the light at the end of the tunnel.
Evan
09-20-2018 | #49 |
Wow! Keep at it, it will be running and turning great times in no time!
09-21-2018 | #50 |
That engine is a beauty alright!
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
