Old 06-22-2018   #11
Marc Haibeck
Default Re: Plenum & Injector Housing Porting
Mercury Marine corrected the port mismatch problem in '93. It was part of the 405 hp upgrade. They CNC blended the injector housing ports 1.5" down the port. They also increased the plenum port diameter from 33 to 34 mm. That's why porting an early engine well will add 35 hp. Only 20 hp can be gained on the '93 and up engines.
Old 06-22-2018   #12
jss06c6
Here's a couple of pictures to illustrate.. note that using the gasket as a reference, the head ports are concentric, while the injector housing ports are shifted, dramatically on the primary runners..[ATTACH][ATTACH]
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 06-22-2018   #13
jss06c6
As point of reference, these are the original injector housings from this engine..
Old 06-22-2018   #14
Steve,
One thing I did when I first ported the top end is to use a double fluted burr (I think that’s what its called) and then I finished things off by bolting everything together and using a 38mm ball hone to smooth out the transition.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-22-2018   #15
jss06c6
Thanks Dominic.. I'm using three different burrs depending on where I am in the runner.
I need to know if this is sufficient removal of the primary injector boss.. hesitant to get deeper, but certainly still have room..
Yes, I touched the face with a burr! Very, very minor..
[ATTACH][ATTACH]
Old 06-22-2018   #16
jss06c6
Took a bit more off.. better transition now..
Old 06-22-2018   #17
jss06c6
Moving on to next primary..[ATTACH]
Old 06-22-2018   #18
tiegsd
tiegsd's Avatar
Just had my original injectors replaced, 4 of them are no good. Happy to donate a couple to the cause.
Sent from my SM-N920V using Tapatalk
1990 Black/Black ZR-1 #1155
Old 06-22-2018   #19
The 90 injector housing is the only one that you can eliminate the primary injector boss entirely as the injector seal is @ the top of the injector. Maybe you realize that, IDK.
More later...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-22-2018   #20
[ATTACH][ATTACH]
If u don’t punch thru, ur not trying. 🤣🤣🤣
