Old 05-10-2018   #1
Vette73
Default Clutch fluid change...
I know the ranger method is good......All you tube videos on how to do this are strictly for C-5 vettes, nothing for C-4......
Excuse the ignorance, there are two plastic capsules near the brake booster calling for Dot 3 brake fluid...Both are pretty dirty......Is one however for the clutch fluid?
Old 05-10-2018   #2
jss06c6
Default Re: Clutch fluid change...
Nope, look for the clutch master cylinder below the ECM. It has its own reservoir. Might be easier to get to if you release the ECM and lay it up on the windshield..
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 05-10-2018   #3
Vette73
Got it...Moved the ECM a few times when swapping out the chip......Ok will check....
Old 05-11-2018   #4
This is really the only way to get to the reservoir.
