Let me know what you have
![]() Join Date: Dec 2003
Dempsey,
Noticed your title for 90~92 head. 90 model injector housings need to be used with 90 model heads. If you use 91~92 injector housings (without modification) with 90 model heads , too much oil will run through the PCV system. You can see the differences in this tech data. http://www.jerrysgaskets.com/fuel-in...housing-guide/
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 05-01-2018 at 11:16 AM. |
BTW, we have quite a few used cylinder heads that have not yet been reconditioned, so are not listed in the webstore. If you are interested, I will check to see what I have. DO you want bare or complete with valves. Need SPT or not?
Hey Jerry!, actually what I need is in 92 head or a 91 head, all of our heads and I h's are modified so a 90 would work, however a 91 or 92 would be the best.
All I need is the bare head no valves are any things as such just ahead and the Cam cover. Dempsey |
PM sent
Got it!...
Sent from my SM-G955U using Tapatalk |
