04-20-2018 | #31 |
Re: Fuel Sending Unit
Do you know what the AC Delco TS number is for the original long sock with the hole in the end?
04-20-2018 | #32 |
ACDELCO TS1
ACDELCO TS3 ACDELCO G1 AIRTEX E3240 AIRTEX E3240 |
04-20-2018 | #33 |
While the ts3 fits and works, it’s not technically correct. The end seams on the original are rotated 90 degrees from each other and the far end has a hole to go over a pin on the housing.
04-21-2018 | #34 |
Gents,
Has anyone upgraded the pumps to the Racetronix (Walbro) 255? Higher flowrate I believe and good quality. Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
04-23-2018 | #35 |
New ACDelco fuel pump/sending unit got here today. Long sock is torn at the bottom heat fusion joint! Guess I'll try to get a replacement, or maybe I can get them t send me a new long sock/strainer? No guarantee that the replacement won't be torn too..same type as in the pic from spork2367 above.
Sent from my XT1585 using ZR-1 Net Registry mobile app |
04-23-2018 | #36 | |
This is the exact problem I just encountered with a new unit. If I can't get a proper replacement, I'm tempted to reuse the sock from the one I just repaired.. Sent from my XT1585 using ZR-1 Net Registry mobile app |
04-23-2018 | #37 | ||
04-23-2018 | #38 | |
04-24-2018 | #39 |
Torn sock as received.. will put Racetronix socks on the unit..[ATTACH]
04-24-2018 | #40 | |
