Old 04-13-2018   #1
Tripler
Tripler's Avatar
Default Tailight Replacement Done Easy
Found this a while back . Easy way to change a burnt rear bulb .
https://youtu.be/VBaeCwgkdqo
Tripler is offline   Reply With Quote
Old 04-13-2018   #2
WVZR-1
Default Re: Tailight Replacement Done Easy
Except that it's for the early C4 and the '90 'base' car. Nothing applies to a '90+ ZR-1.
Old 04-13-2018   #3
Tripler
Tripler's Avatar
So we can't do it that way for the ZR-1's ? Bummer .
Thanks for the update .
Old 04-13-2018   #4
lfalzarano
You aren’t suppose to use the middle pedal, just the right one and occasionally the left one! [emoji41]
Old 04-13-2018   #5
Tripler
Tripler's Avatar
Lol good one ...
Middle pedal is overrated
Old 04-14-2018   #6
Here's a pic. Notice the screws, left n right...
Mike, if it's any consolation, I removed the license plate frame BEFORE I noticed the screws in the lens!! DOH!!
Old 04-14-2018   #7
Tripler
Tripler's Avatar
Oh ok . Thanks Paul ... It's still winter here and the car is still covered . My bulbs are fine . I just thought that method would work for our cars but it does not .
I will do a little better research next time before I post info .
