Old 04-01-2018   #31
George Maz
Default Re: Optima or Odyssey ... close dimensions, will it fit? ---
Stinger short bolt must be shimmed by using brass colored plate, flat washer, lock washer ...or cut thread length and run threads before installing to terminal threads. I prefered the addition contact area by using the plate.
Install is '96 CE, no battery disconnect retains the key fob proximity door unlock&lock feature.20180331_123946.jpg
Sent from my SM-N920V using Tapatalk
George Maz is offline   Reply With Quote
