Old 03-03-2018   #1
Reichert
Default Oygen sensor removal, passenger side
Any tips on disconnecting the passenger side O2 sensor on a 1990? It's jammed way up in there and I don't see an obvious way to get to it.
I just got the car and haven't picked up the service manuals yet - still deciding between print and online.
Reichert is offline   Reply With Quote
Old 03-03-2018   #2
Young1
Young1's Avatar
Default Re: Oygen sensor removal, passenger side
I did it recently. Remove the angle frame brace. It looks like it holds up the motor but it doesn't. The connecter is then accessible. Not at all difficult.
Steve Young
Second Owner
SOLD
SOLD
Old 03-03-2018   #3
Reichert
took a peak under the car again and yeah, that makes sense - i'll give it a try and report when I can and report back. Thanks!
Old 03-03-2018   #4
Young1
Young1's Avatar
Be sure to install a Denso or a Bosch. The cheapies don't work.
Old 03-03-2018   #5
Suggest AC/Delco from Rock Auto
instead.
Old 03-03-2018   #6
Reichert
instead.
I had already purchased the Bosch sensors (13077). Well ... I bought them on Amazon (3rd party vendor), and I received 2 Bosch branded boxes - only one of them had the correct part in it. *sigh*
Old 03-03-2018   #7
Young1
Young1's Avatar
I bought a pair of Bosch on Rock Auto. Good pricing you just have to wait
Steve Young
Second Owner
SOLD
SOLD
Old 03-04-2018   #8
I concur with Dominic. The Bosch (in particular) would become intermittent at times - causing me "a little" angst!
But, the REAL angst was accessing the sensors to remove and reinstall them!
The "fix' was plugging the top mount bungs and installing new ones facing laterally toward the frame rails. What a good idea that turned out to be! (I placed them at about 80-85º from vertical to my SW header collectors. I've NO problems with them being damaged when bottoming out (i.e., speed bumps, etc), and heaven knows I've tested them!!)
O2 (weld in) Bungs: Summit Racing: #SLE 30115
Old 03-04-2018   #9
Reichert
The "fix' was plugging the top mount bungs and installing new ones facing laterally toward the frame rails. What a good idea that turned out to be! (I placed them at about 80-85º from vertical to my SW header collectors. I've NO problems with them bottoming out, and heaven knows I've tested them!!)
I really didn't have an issue accessing the sensors, using a slotted 3/8ths offset wrench.
Per XfireZ51 and your advice, I went ahead and ordered the delco sensors from rock auto, since I only had one useful bosch sensor from my amazon order.
-Stephen
Old 03-07-2018   #10
Plugging the thing in is a real challenge. What I did was put a wad of dumdum on the end of a long thin screwdriver and started the plug into the other end and then used another long screwdriver to push the plug together. Dumdum is seam sealer.
