Old 01-30-2018   #1
Billy Mild
Default Backup lights not working
How difficult is it to replace the reverse light switch?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 01-30-2018   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Backup lights not working
Big hands? forget it.
Little Hands, you might be OK.
Either way an O2 Sensor socket makes it much simpler.
Most new switches are unlike the original, and are simpler to install once the old one is removed.
Most times the original switch is still operational, but just needs a thorough cleaning in order for it to work again.
Marty
Old 01-30-2018   #3
efnfast
I bought a box wrench and cut the handle off. Still in my toolbox.
Old 01-30-2018   #4
billschroeder5842
billschroeder5842's Avatar
Well....
You will want (need?) to get the car off the ground. A lift is best.
DRM500 is correct; you need to have little kid hands as the switch is WAY up on the transmission
I went to a "jiffy quick oil place" and rolled the car on the "oil pit" The young fellow below was able to reach up, unplug and put a wrench on my switch. In and out in 15 minutes. They did not want to charge me, but I brought a case of beer for the crew and they were way more happy.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 01-31-2018   #5
32valvesftw
Originally Posted by billschroeder5842 View Post
Well....
Probably the best use of a Jiffy Lube I have ever heard of!
