Old 12-10-2017   #21
Default Re: Coolant Recommedation
Originally Posted by Marc Haibeck View Post
Here's an update about green formula coolant availability. I believe that it is still important to stay with the OE type color coded green coolant. Green coolant can be hard to find. Some auto supplies will try to sell "universal" or some other coolant because that is all they have. It might take some searching but green coolant is still available.
As of this date AutoZone has it in their house brand. Part number A003.
NAPA has it in their house brand. Part number NAF1GAL. The NAPA near me also has the Zerex brand. Part number ZRX ZX001.
A local independent auto supply stocks it because they want to support the classic car market. It's labeled FVP Original Green Formula. Part number FVPGreen-Gal. It's distributed by FVPparts.com.
RADIATOR COOLANT additional photos of Marc's recommendations
You want to only use the green coolant. They have it at Napa and it meets 1825M GM Spec.
For Zerex the first gallon is called Regular Green Coolant (GM 1825M), the second gallon is called Original Formula (GM 1825M). Zerex ZXRU1 is 50-50 and Zerex ZX001 is undiluted. The third gallon is NAPA coolant (GM 1825M).
OROR
NAPA
Old 12-10-2017   #22
Jagdpanzer
Jagdpanzer's Avatar
Marc,
Thanks for updating us.
Besides the OEM head gasket in your experience have you seen any other area of the LT5 engine that is negatively effected by not using the recommended 1825M type antifreeze?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-17-2017   #23
Marc Haibeck
I have not noticed any other particular corrosion problems Phil.
Old 02-05-2018   #24
jrd1990zr1
jrd1990zr1's Avatar
All,
Was just at Autozone. Part # 540722 now has code AZA003 on it. Green conventional. It looks to be the correct product.
Marc, can you confirm that the AZA003 is still the correct coolant?
Thanks
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 02-05-2018   #25
HAWAIIZR-1's Avatar
Default Coolant Recommedation
I could not find GM 1825M in Japan, not even on military bases since they only carry Prestone. I almost settled for Prestone, but after consulting with Marc, I kept searchIng the inter web. Fortunately, Advance Auto Parts could ship Carquest Conventional Green stuff to me and it’s on the way. [Thank you Marc! ATTACH]7016[/ATTACH]
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 02-07-2018   #26
Marc Haibeck
I think that the AutoZone AZA003 is a good choice.
Old 10-31-2018   #27
jpalmer1717
Buy premixed? Or 50/50 myself?
jpalmer1717 is offline   Reply With Quote
Old 10-31-2018   #28
Ccmano
Premix is just easier. Makes no difference.
H
Old 09-17-2019   #29
max76
Hi guys,
i'm from italy and i cant find your product. Do you think that a common green coolant is good for my lt5?
How many liters need?
Thanks
max76 is offline   Reply With Quote
Old 09-17-2019   #30
lfalzarano
http://www.zr1.net/forum/showthread.php?t=21601
15 quarts or 14.2 liters
http://www.zr1specialist.com/HAT%20W...%20Coolant.pdf
