Old 11-04-2017   #1
davekp
Default Brighter dash lights
Is there a way to make the dash lights on a '90 brighter during the daytime? I replaced all the bulbs but that didn't help. It's vert difficult to read, especially with sunglasses.
davekp is offline   Reply With Quote
Old 11-04-2017   #2
Ccmano
Ccmano's Avatar
Default Re: Brighter dash lights
It’s not the light bulbs. The ambient light sensor (photo cell) has gone bad. A common C4 issue. It is located in the upper left corner of the DIC panel above the buttons for the fuel data and such. You will see a small hole there, the sensor sits in there. I have the same issue. The sensor can be replaced by itself. This outfit does the repair or will send you the part (BATEE.com). Or, like me, you can replace the whole DIC unit. My fuel data buttons were intermittent so I decided to replace the whole thing.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-04-2017   #3
BigJohn
BigJohn's Avatar
Do you have the dimmer turned all the way up?
Maybe try a different type sunglasses!
Old 11-04-2017   #4
Ccmano
Ccmano's Avatar
Yup, dimmer has little affect in daylight. If you turn the headlights on at night you will see that the dimmer works great.
H
Old 11-04-2017   #5
H
This is correct it's the photocell especially if the display is easy to see at night time with the headlights on. Also any polarized sunglasses will make the display a problem to see in the day. My sunglasses play havoc with my wife HUD in her car. GC
Old 11-09-2017   #6
Bob Eyres
The display on my 91' looks faded out and weak, hard to read. Is that what
You're talking about?
Does replacing the sensor give greater contrast? Or do you have to replace the whole DIC? (Dash Instrument Cluster?)
What's the best source for this? Price?
Thanks.
Old 11-09-2017   #7
Thanks.
www.batee.com..
you are going to need a new LCD polarizing film if your display is faded
Old 11-09-2017   #8
WVZR-1
OP - if the LCD seems presentable/acceptable with no sunglasses then quite likely your issue is with the "polarization" of your sunglasses. You could maybe spend much money on the cluster improvements and if your glasses are polarized your very likely to still have issues.
FLORIDA hints maybe "polarized" eye wear!
Old 11-09-2017   #9
In the mean time, if you switch on your fog lights, the DIC brightens and becomes visible, even w/ sun glasses - at least true for my non-polarized "sunnies".
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-09-2017   #10
Ccmano
Ccmano's Avatar
There are three major known issues with the 90+ C4 instrument pod.
1. Poor day time illumination. This is a lighting issue caused by the failure of the photo cell as discussed above.
2. Fading of the central lcd display. This is caused by failure of the lcd display itself and can result in the display characters virtually disappearing. This is the issue the second OP likely has.
3. Incorrect tach readings. Sometimes the tach needle will peg itself to the top or bottom of the display but generally just a noticeably inaccurate tach. Caused by failure of the control chip for the tach.
As noted polarized sunglasses can have an affect similar to #1 and 2. However that is easily eliminated by simply elvaluating the display without wearing them.
These items can all be resolved by the company Paul noted above. They can either do the work for you or sell you the parts to do it yourself.
H
