Old 08-22-2017   #1
rbidwell
Smile Raptor twin turbo
Corey Henderson is in the final stages of tuning the 90's Raptor twin turbo project. He said it should be done this week.
rbidwell is offline   Reply With Quote
Old 08-23-2017   #2
Ccmano
Default Re: Raptor twin turbo
Is this one of the Raptors that Ron Hanselman was working one a few years ago. What ever happened to that project. Last I heard tuning was an issue.
H
Old 08-23-2017   #3
rbidwell
This is Mr. Hanselman's project. Corey Henderson has re-designed parts of the system. If I understand right Corey had the car running on the original ecm, but is now tuning using the mega-squirt system. He has not mentioned any tuning problems, but I guess we will know in the next few days.
Old 08-24-2017   #4
gbrtng
gbrtng's Avatar
Ron, are you coming to New Braunfels to pick it up?
Old 08-24-2017   #5
Was this a low compression LT5 build as well ?
Old 08-24-2017   #6
rbidwell
Yes, I will be going to New Braunfels to pick up the car, if I don't get it sold first. This is a low compression build. I think 9:1. Lozano Brothers did the machine work on the engine which has new rods and pistons. Corey suggested original cams and that is what it has. The engine had been ported and polished at South Georgia Corvettes. Also has new clutch and pressure plate with bigger after market radiator. It is a 368 ci.
Old 08-28-2017   #7
Bob Eyres
So figuring around 540/550 chp. For a NA 368 with those mods. What is the speculation it might be with the turbos?
Old 08-28-2017   #8
rbidwell
Around 615 rwhp.
Old 08-29-2017   #9
Billy Mild
Only 615? I hope that is at low boost.
Old 08-29-2017   #10
rbidwell
Should be around 9 psi. That is around 725 hp at the engine. I'm guessing Corey is busy trying to stay dry right about now.
