Old 08-14-2017   #51
cp1joel
Default Re: Injector issue with 1990?
Hmm after doing quite a bit of research I came across a thread with the exact same issue and same symptoms.
SES light stays on, fan on.
Throwing the same code (c41)
turns out to be the optispark /distributor.
Will begin to look in this direction
http://www.corvetteactioncenter.com/...e-9-h72-6.html
cp1joel is offline   Reply With Quote
Old 08-14-2017   #52
QB93Z
QB93Z's Avatar
The LT5 in a ZR-1 does not have an Optispark.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 08-15-2017   #53
cp1joel
Oh right, I assumed the LT5 used a similar distributor to the LT1.
If that is the case, I am still leaning towards a bad ECM.
Old 08-18-2017   #54
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
ECM's, while known to fail, particularly if they get an electrical surge from a high powered charger, usually are rather robust in a C-4.
I would suggest searching for a faulty wire first.
You and others have been doing a lot to that car recently, so it is not impossible that the ECM took a dump, but I would rule out the higher probability causes, such as loose connectors, shorted wire etc.
You will likely have time to perform those checks as an ECM may take some time to locate.
Let the FSM be your friend and follow it's diagnostic protocols.
Good luck and keep us posted.
Marty
DRM500RUBYZR-1 is online now   Reply With Quote
