Old 07-07-2017   #21
Default Re: License plate LED bulb upgrade
Jeff,
I've seen LED bulbs for signal and tail lamps at AutoZone. Was tempted to try them when I did the Euro lamp conversion but w 8 bulbs needed it was going to be a bit pricey.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-07-2017   #22
Rear is no problem.. front side marker and front LED Turn signals are where the issue lies
Old 07-07-2017   #23
When u say front side marker you mean cornering lamps, correct? Because I have LED in side running lights. Or are thise supposed to blink w front turn lights?
Old 07-07-2017   #24
No, the amber light, not cornering. Cornering is a different circuit.
AMber will flash in sync with turn signal when parking lights are off. when parking lights are on, it flashes 'off' opposite when turn signal is 'on'
Old 07-07-2017   #25
No the cornering lights are clear (white). They simply turn on which if you think about it is pretty cool for 80s tech. But no Dom those just turn on when you indicate the turn at the signal stalk. If you don't drive your Z at night or early morning like I do you may not even know that light is even there. GC
Old 07-07-2017   #26
-=JEFF=- is correct
Old 07-07-2017   #27
Has anybody looked into the non error already resisting bulbs for the amber bulbs yet
Old 07-07-2017   #28
Not sure what you wan by non error already resisting bulbs.
Old 07-07-2017   #29
For wife's older Mercedes I converted all her bulbs to LED. The Mercedes had a DIC more up to date than that our 80s era cars however, with LEDS the car DIC would display error codes in the digital DIC unless the LED replacement bulbs you bought were sold as "non error" which means the bulbs were sold with a internal resister from the source to fool the DIC. So...... now with that being said has anybody here brooched the amber turn signal bulbs with amber non error bulbs to solve the problem. GC
I may do this when it's not 118 out here in Hellazona
Old 07-07-2017   #30
Got it. To me, while nothing wrong with it, does not improve the load on the electrical.
