Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 07-03-2017   #31
Roadster
Roadster's Avatar
Default Re: Working on the 74.....
Today's progress, heater box installed and also lifted the original top on the car. Most of its life has been under the deck lid. Not in bad shape for being original. Some spots need attention and there is on hole that needs to be patched, which may be possible. Back window is very near perfect, especially for the age.
Also made some adjustments on the rear deck lid. Since the top has shrunk over the years, it needs to be stretched out. But everytime we got the top connected, the RR deck lid would pop up and sometimes the LR too. So we determined that the RR mechanism needed adjustment. Had to add two washers to the locking bracket to bring it out to make a good tight secure connection. Problem solved, as now the top is fully attached and the deck lid is in place with no movement at all.
you can see the deck lid on the LS raised...
another view...
adjustments made....nice and flush....
you can notice the small hole towards the top on the RS...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-03-2017   #32
Roadster
Roadster's Avatar
Those magic numbers.....lol although years of dust and grime, it still has a meaning....lol
one of my partners in crime....old high school buddy from way back when...always had the top down in his Rebel SST no matter what the weather was outside....lol...lol
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-07-2017   #33
Roadster
Roadster's Avatar
For those who have an interest, I started a new FB page recently called...
https://www.facebook.com/groups/LS4454/
It is about the BBC's with the Mark IV Engine from 1965-1976. Check out our page and request to join, especially if you have an interest or are already a BBC owner...
Thanks....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-12-2017   #34
Roadster
Roadster's Avatar
Doing more work on the 74 today. Presently in the process of wiping down every wire in the wiring harness that I can get my fingers on. Not too bad to begin with, but years of dust, slight grime and some electrical tape needing repair needed to be addressed.
Glad I marked everything years ago, otherwise I be in a real mess....lol
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-12-2017   #35
Roadster
Roadster's Avatar
Continuing on in the day, things going well. Took the heater box out again for the last time....lol Connected vacuum hoses to the proper locations and hooked up some of the duct work. Sometimes you learn as you go along, because maybe you have forgotten what you once new from years ago...lol or maybe the instructions were all not that great, or you didn't take certain pics or make notes when things came apart...lol
But anyway, as I was putting the duct work back together, I couldn't get the center piece back on to the side the heater box. Of course I installed the foam gaskets ahead of time, and in this particular assembly that was not the correct thing to do. So out comes the gasket and I had to peel off all of the adhesive material used to hold the gasket in place. Thankfully it was still very pliable which helped out tremendously....whew....
Got it all cleaned off and proceeded as planned. So far so good. Also dropped the top for more working room and it is starting to stretch, as it took very minimal effort to get it back in place....
top down....
getting the vacuum hoses in their correct locations...
box back in....
part that wouldn't fit onto the box until I moved the foam gasket...
sealant I had to peel off...lol
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-12-2017   #36
Roadster
Roadster's Avatar
making progress...notice the gap between the center piece and the defroster vent. that will get tape around it to prevent air loss. the quality control wasn't the best back then and we wonder why the HVAC system never worked as intended....lol
a close up of the gap...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-17-2017   #37
Roadster
Roadster's Avatar
I stand corrected from the photo above which shows a wide gap. I think that I can close that gap considerably, but will still need to use tape to keep sealed....
Did some minor items on the 74 today, nothing major......took out the center HVAC duct again....lol to reposition the vacuum hoses to go under there....still want to make sure I have them in the correct location...I should have taken more pics...lol and I do have the AIM, but for some reason this job is KIA.... also tried to clean the white top. Tried different cleaners and although there is a slight difference, I am sure there is something out there to get rid of those stains. I am thinking about using straight bleach. If anyone has any suggestions, they will be appreciated.....thx....
view from the RS...lol
view from the LS...lol
already started cleaning....
little improvement....
there is a slight difference, and notice the difference from under the back window...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-23-2017   #38
Roadster
Roadster's Avatar
396/427/454 Mark IV BBC Engines 1965-1976
It includes the BBC's used in GM Chevrolet vehicles from 1965-1976.
Check out our page and feel free to join, especially if you have an interest in the BBC's from that time era.....
Thanks....
The name of the Group has changed slightly and is updated above....we continue to grow on almost a daily basis...
The Group includes BBC's from 1965-1976
Thanks for looking....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-07-2017   #39
Roadster
Roadster's Avatar
Went out to the 74 yesterday with my oldest grandson. We had a great time and got somethings accomplished. He was anxious to wrench and really enjoyed the outing. I let him get a hands on feel for what and why we were doing what we did. Needless to say, he also really enjoyed working on the car....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-14-2017   #40
G-Sting
G-Sting's Avatar
Attachment 6413Attachment 6414Attachment 6415
Tom,
Looks like that young man is learning a lot from you. What great memories you are making with him. Keep it up, sir!
G
P.S. Since Photobucket is now defunct for me, I'm attaching another pic of the '79. It's in front of the Churchill Downs corporate building that I took after driving it this weekend. :-).
File Type: jpg '79 L82 4-spd in front of Churchill Downs Bldg.jpg (139.1 KB, 13 views)
'94 ZR1 LT5 - Dark Red Metallic
'79 L82 4-speeds of fun
'96 LT1 Borla, H-pipe, TB, CAI (Sold)
"An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton
G-Sting is offline   Reply With Quote
