Old 05-21-2017   #11
WVZR-1
Default Re: Itty Bitty Bulb needed
Originally Posted by Young1 View Post
Gentlemen 74 is not the bulb. Open the link of BlackZR1. The black and orange is the bulb. But 10148011 is the part number for the door switch assembly that contains the bulb. GM does not have a part number for the bulb itself. WVZR1 is on track with the T3 or T5. Anyone have a source?
I posted an insert from the FSM documenting the part# that was posted. I can confirm the part # in "larger font" if you need from several GM SPO publications. I mentioned "if you have bulb in hand to compare dimensions to the T3 and T4" - I wasn't "on track" - you're the guy with the bulb/socket in hand.
It ain't a #74
here's an entry from SPO - switches and LAMP/BULB in same parts group!
Old 05-21-2017   #12
74 is the size for the door lock bezel night glow and the under mirror light. I just pulled the bulbs from spare switches in my parts crib. You are correct they are not a size 74. I have never seen those small orange bulbs at a car parts store before. Sorry I could not be much more help apparently I've replaced every blub inside but those. Let us know if you come up with a solution it looks like $25 is the going rate from KW Racing.
Old 05-21-2017   #13
It ain't a #74
I cited your post #6 in -Solutions- Under Post #3 ZR-1 Electronics earlier......
so when you guys get the part number/source figured out........edit your Post #6 here......as that post seems to have the most technical information
Old 05-21-2017   #14
WVZR-1
I cited your post #6 in -Solutions- Under Electrical earlier......so when you guys get the part number/source figured out........edit Post #6 as that post seems to have the most technical information
See post#11
Old 05-21-2017   #15
Young1
Young1's Avatar
Will do. Heading out on road trip with the z to the Carolinas on Tuesday. Will disassemble and measure on return. You all are great and we learn and share together
Steve Young
Second Owner
SOLD
SOLD
Old 05-21-2017   #16
See post#11
I see that also in post #6...........
Old 05-21-2017   #17
WVZR-1
#6 is from a later FSM - #11 is from SPO with part#'s also for switches through '93 which is the last paper production of SPO.
Old 05-21-2017   #18
Well......yes....I see that now.......will wait until this is resolved and then "link the post" wherever the correct information resides
Old 05-21-2017   #19
10148011
https://www.gmpartsgiant.com/parts-l...-exterior.html
Lists them but in limited qtys
Old 05-22-2017   #20
Roadster
Roadster's Avatar
Happened to be in Walmart, and picked up a #74 anyway, even though it has been mentioned that it is not correct.
Has new packaging and shows a color chip on the RS...
Sent from my SM-G935P
1974 LS4 454 Vert
1974 L-82 355 Vert.
