Old 05-17-2017   #1
Young1
Young1's Avatar
Talking Itty Bitty Bulb needed
Where do I get the little bitty light bulb that illuminates the electric window switches? It removes from the body of the switch with a tiny screwdriver. It is a yellowish orange color. Burnt out. I am type A and enjoy victory over the small things too.
Old 05-17-2017   #2
Roadster
Roadster's Avatar
Default Re: Itty Bitty Bulb needed
If possible see if there is still a legible part number on the bulb. Then check the parts stores, etc. I have never seen any listed for that application.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-17-2017   #3
BlackZR1
BlackZR1's Avatar
My parts book says 10148011:
http://www.ebay.com/itm/NOS-OEM-GM-L...VXq42x&vxp=mtr
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 05-18-2017   #4
Young1
Young1's Avatar
Thanks so much. Part number is accurate for complete switch assembly. The itty bitty bulb is not a separate part number. Maybe I can find one at Carlisle. A 1,600 mile road trip for a $1.60 part makes sense to me![emoji41]
Steve Young
Second Owner
SOLD
SOLD
Old 05-21-2017   #5
$25 for a bulb,why do people keep doing business with that hack.
Old 05-21-2017   #6
WVZR-1
"BlackZR1" posted correct information for "just bulb".
This is the bulb only!
OP - I've never attempted to match the bulb/socket and I've only ever seen it referenced to a Stanley #
If you've the bulb/socket removed presently I'd try to compare dimensions to a T3, T4. Dimensions are in the link.
http://www.autolumination.com/74.htm
Easier to read dimensions
https://www.ebay.com/p/?iid=382069402972&&&chn=ps
Many years ago I did several switch back-lighting projects for other than Corvette projects that used some Pontiac/Olds/Buick lighting. I believe I actually sourced most of the project using MOPAR.
This is from a later C4 FSM - Bulb charts are in the 8B & 8C sections of the FSM. The Stanley reference information is there also.
Old 05-21-2017   #7
Young1
Young1's Avatar
Now we are on to something with the auto illumination link. I will continue with updates. I will get some extras to share!
Steve Young
Second Owner
SOLD
SOLD
Old 05-21-2017   #8
It's a Sylvania Size 74. I have replaced them many times before. However just reading the thread above it appears WV has you in the right direction. GC
Old 05-21-2017   #9
Twin pack for under $2.00!
https://www.walmart.com/ip/Sylvania-...&wl13=&veh=sem
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-21-2017   #10
Young1
Young1's Avatar
Gentlemen 74 is not the bulb. Open the link of BlackZR1. The black and orange is the bulb. But 10148011 is the part number for the door switch assembly that contains the bulb. GM does not have a part number for the bulb itself. WVZR1 is on track with the T3 or T5. Anyone have a source?
Steve Young
Second Owner
SOLD
SOLD
