Old 04-21-2017   #1
billschroeder5842
billschroeder5842's Avatar
Default Any factory exhaust tip performance mufflers?
I'd like to add a bit of sound (not boy racer) but have not found any muffler that uses the same shape or dimension of factory exhaust tip?
Yes, I'm OCD, but I REALLY like the symmetry between the exhaust tip shape and the tail lights. Yes, It's my "my weird" but I can't mix and match shapes. My C3 was WAY easier as round tail light and round, single exhaust tips just worked.
I really like how the ZR1 looks from behind (That makes me an "*** man"?) and I'd hate to mess up the look. Are there any decent exhaust systems out there that use the same factory exhaust tips? If not has anyone modified a performance muffler using the factory tips?
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 04-21-2017   #2
BigJohn
BigJohn's Avatar
Default Re: Any factory exhaust tip performance mufflers?
A good muffler shop could cut off stock tips and weld them on to new mufflers.
Old 04-21-2017   #3
ghlkal
ghlkal's Avatar
Bill, I completely understand this ...
I had to have the stock tips on my GXP, so I did as BigJohn suggested and had my stock tips welded on the aftermarket mufflers.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 04-22-2017   #4
WVZR-1
A bit "off-topic" maybe!!
Is this a G8 GXP? Would you do the G8 again?
Old 04-22-2017   #5
ZR1North
I totally get this, Bill. I had Banks exhaust tips fitted to my Corsa mufflers to get that symmetrical look (as close as I could get). Funny that a GXP is mentioned; I had a GP GXP and when I replaced the mufflers, I had to fit the factory tips to the replacement mufflers since I could not find anything close enough to the factory tips. I was going to replace the GP GXP with the G8 when I traded but when I learned GM was going to drop the Pontiac line, I kept the GXP until I traded it on a Z06 last fall.
Kudos for paying attention to detail; I agree that those 90 and 91 tips add a lot of character to the rear of the ZR-1.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades
2016 Z06 - Stock
1971 Stingray 454 LS5 - Sold
ZR1North is offline   Reply With Quote
Old 04-22-2017   #6
Here's a pair of Dynomax Ultraflow muffs using OEM Z06 tips welded on. This includes use of the NPP valves in one of the tips.
Old 04-22-2017   #7
billschroeder5842
Thanks- The Banks tips look pretty close. There are two the (52909, 52919) that may do the trick.
Attention to detail? Thanks, but I figured it was just my OCD Hobgoblin.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 04-24-2017   #8
JThomas
JThomas's Avatar
Bill:
Isn't it nice to know, you are not alone with your OCD situation?
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 04-24-2017   #9
billschroeder5842
Originally Posted by JThomas View Post
Bill:
So, you will appreciate that I spent my lunch pulling apart the dash, trying to find a small squeak. I'll know if if I got it on the home commute!
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
