Old 03-27-2017   #11
tpr60
Default Re: Cam Timing Pins
Interested in a set also, price?
tpr60 is offline   Reply With Quote
Old 03-30-2017   #12
jimmil
Just curious, but how much play is there? The original GM pins can move as much as 6 degrees after they have been pinned. You always had to plan on that when timing the cams and the force exerted on the cam bolts when you tightened them down. You may have thought you had the perfect 110/116 timing but when you checked them no telling where the timing ended up.
jimmil is offline   Reply With Quote
Old 03-30-2017   #13
He's still alive!! Hi Jim
Old 03-30-2017   #14
jimmil
Don't tell anyone... It's a secret... Yeah, we need a beer.
Old 03-31-2017   #15
Jagdpanzer
Jagdpanzer's Avatar
Hi Jim, glad to see you back on here.
I learned everything I needed know about cam timing from your write up.
http://www.zr1netregistry.com/Information/TechNet/[AllArticles]/tabid/262/articleType/ArticleView/articleId/212/LT5-Cam-Timing.aspx
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-31-2017   #16
jimmil
Hows that square engine treating you? I hope everything is going well and the car still scares you.
Old 03-31-2017   #17
Jagdpanzer
Jagdpanzer's Avatar
The 4x4 was a rocket but had to come out for the original stock motor in order to get through the tough emission inspections we enjoy in Northern Virginia. This time it will go back in as a 427 using the 4" stroker crank again and this time with 4.125" bore liners and pistons which should give it a little more giddy up. As you Texans are fond of saying "to much is never enough"
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-14-2017   #18
tnova
Phil,
Count me in for a set too. Perfect timing as I have the engine out of my '91 for a rebuild, 160k miles.
Tony
tnova is offline   Reply With Quote
