![]() Join Date: Nov 2016
My trans is shifting harder than it should so I think a fluid change is in order--- the car has 70k on it and God knows how much on the fluid.
So, my research says that AMSOIL is a safe, dependable, no risk solution. Can I change it in the driveway or is it just best to take it somewhere where there is a lift/pit and the disposal is the other guys problem? I'm happy to spin the wrench and prefer to do my own work, but I'm old enough to weight risk/reward.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
![]() Join Date: Feb 2010
You can do it. It helps a lot to have a second person to snake the funnel and hose you make down between the engine and firewall when refilling.I do it every 15,000 miles so it can't be too hard.
Gary 90-1572 ![]() |
![]() Join Date: Jan 2006
Take out the fill plug first. I think it's a --mm BMW/vw tool at auto parts. Use a crescent wrench (or open end wrench) to get right up to fill/drain plug so as not to round off plug. Pipe fitting tape or thread sealant on install. Filling is a bear but the $5 hand pump at auto parts work great. 2.2qts.
Ted Gary is correct below on size--deleted to not confuse anyone. Last edited by Demps; 03-16-2017 at 09:07 PM. |
I believe it's 17MM allen for drain and fill. May want a couple new plugs handy if the old ones are messed up. A new small pipe wrench with sharp teeth will get the plugs out if there stripped. The pump for refilling is a good idea if by yourself.
#5 | |
![]() Join Date: Mar 2014
http://www.zr1.net/forum/showthread.php?t=27276 Another alternative tool to have for the plugs.....get yourself a 17mm 3/8" drive Allen socket to fit the plug.
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 03-16-2017 at 09:32 PM. |
I didn't know you were supposed to use thread sealer on the plug. I will do this next time so it doesn't leak.
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration |
![]() Join Date: Apr 2007
Use some Permatex anti seize on the plug when reinstalling and shouldn't leak plus it will come out easier the next time. Snug it up good but don't over tighten.
#8 | |
![]() Join Date: Jul 2005
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
#9 | |
I called up the local VW guy and they said that the only one (one) and the shared computer said it was in McKinney Texas. While a good size town, McKinney in BFE compared to the rest of our urban sprawl. But, I did not mind taking the road trip this afternoon as it was about 30 miles and I was able to have some fun with a C6 and a CTS. The Vettes clearly had the pulling power over the Caddy as we hit above the century marke more than a few times. So, with one, I have to have a 50% success rate on the old plugs. I'll give it a shot this weekend a see what happens.
#10 | |
Sounds like you had fun getting the only one!!! I have extras, so if you want to hold off, or you get stuck getting both plugs out, PM me your address and will be glad to mail one down to you....
