Old 03-11-2017   #11
G8nightman
G8nightman's Avatar
Default Re: 90 - 765
I have one on the list to install.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 03-11-2017   #12
Roadster
Roadster's Avatar
If you have an Advance Auto Parts in your area, they have this available...
From their web site...
"Kidde Safety*FC5 Fire Control Fire Extinguisher
Part No.*4104000-A
$18.29
Suitable for use on Class B (liquids & gases) and Class C fires (energized electrical equipment). The Auto unit is fitted with a "one touch" pressure check device to ensure reliable performance. It is manufactured from lightweight aluminum and a tough nylon valve assembly. The Auto unit is supplied with a "No drill" velcro mounting bracket.
Product Features:
Clear instruction label using graphics to show steps required to operate extinguisher
Easy-to-pull safety pin
Rust- and impact-resistant nylon handle
2 lb. of fire extinguishing agent (average)
UL, US Coast Guard approved"
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-11-2017   #13
ghlkal
ghlkal's Avatar
Originally Posted by Ryan Chappel View Post
Does anyone carry an extinguisher onboard?
Yes. Over the years I've had to use an extinguisher 2 or 3 times also. Without it, the results would have been catastrophic. I was even able to help out a fellow C4 driver once.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 03-12-2017   #14
Racinfan83
I would say house fire on that one as well. Usually the FD won't let one burn to that extent on the road due to pavement damage...
I think this has been asked before - but do we have any reliable idea how many Z's actually exist? Knowing the actual numbers might help with value...
Old 03-12-2017   #15
oricale
Originally Posted by Helium3 View Post
I've got 10 bucks that says Dempsey will buy this
😂...couldnt live with myself to use the parts for an engine build, and its "JUST a bit outside!"(major league) of my expertise!!!😢😢😢
Sent from my SAMSUNG-SM-G935A using ZR-1 Net Registry mobile app
oricale is offline   Reply With Quote
Old 03-13-2017   #16
Part No.*4104000-A
$18.29
Product Features:
That Exact model saved Xfire's (Dominic's) 1984 from going up in flames..
I need to get a new one for my car
Old 03-13-2017   #17
Arctic91
Arctic91's Avatar
Originally Posted by KILLSHOTS View Post
Vehicle won't start.
Shocker. Probably VATS... I'd try cleaning the chip in the ignition key first. It could be something as simple as that.
Scott
Arctic91 is offline   Reply With Quote
Old 03-14-2017   #18
tccrab
tccrab's Avatar
Scott
Might be the battery, it looks a little burnt up.
'Crabs
Old 03-15-2017   #19
Roadster
Roadster's Avatar
Fire Extinguisher update....forget about Advance Auto....the one they show on their web site with the Velcro attachments are not the ones they have in the stores, at least not in my area. Also the one I had purchased there, the safety tab did not spring back into position for the safety test. So back it went. Drove over to HD and found the same size unit also by Kidde, but a different style as shown in the pic. Has a needle to let you know if it is full, and ready to go. Think I will attach some Velcro myself for a neat install. Price was the same, so for $21 and change, (tax included) you are protected.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-15-2017   #20
ssrszz4
How many pounds is that one?
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
