Old 01-05-2017   #11
edram454
edram454's Avatar
Default Re: 63mm Throttle body
it makes me wonder whey they didnt make them bigger seeing it was a dohc engine. my c5 z06 has a lsx 102mm throttle body and maf. quite a difference.
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 01-05-2017   #12
One thing people may not realize is that you just don't slap on the 63mm TB. In order to take advantage of that, the plenum openings need to be port matched otherwise, what's the point?
Also, now that u have increased overall air intake, guess what? U need to tune the calibration to take full advantage of it.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-05-2017   #13
tpepmeie
According to Marc, even bored, stroked to 378 with head porting and top end porting, may pick up 5 hp at high rev.
The only real way to determine whether it's a restriction is to put a vacuum sensor/gauge on the plenum at WOT. If you're pulling more than .5" Hg depression in the plenum, then you'd do well with a bigger TB.
My 427 w/ 63mm and oversize primary blade was over 1" depression at 7000 rpm. Too much restriction. Short of machining one from billet, there just really isn't any way to go bigger, although I am considering making an adapter plate to fit a big oval body to the front of the plenum.
I'd guess a stock displacement engine at 7000 rpm isn't pulling that much vacuum with a stock TB.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 01-05-2017   #14
edram454
edram454's Avatar
an obvious design flaw. there should have been a way to drastically increase the opening of the throttle body as they have done with all the ls engines. it is a very limiting factor.
EDRAM454
Old 01-09-2017   #15
Hog
Any serious GEN 3/4 SBC uses more than a single throttlebody anyways.
A design flaw? Less than 1% of LT5's would find the 63mm r-body sizing any sort of limitation.
peace
Paul
Old 01-09-2017   #16
Hog
On your 427 with the 63mm t-body, what was you MAP sensor indicating? Was it coinciding with the extra instrumentation you had added? Just curious.
peace
Paul
