Old 10-30-2007   #1
Jagdpanzer
Jagdpanzer's Avatar
Default 63 mm Throttle Body
I see a lot of Z owners mention 63mm throttle body as one of their mods.
Who makes it and about how much $?
How does it differ from the stock throttle body and when does this mode make since?
Old 10-30-2007   #2
Jeffvette
Default Re: 63 mm Throttle Body
The two big blades inside the TB are a 58mm size. The bore is enlarged to 63m and new butterflies are cut out and mounted up.
Cost is around 300.
The gain on a P&P plenum and injector housing set is minimal.
Old 10-30-2007   #3
Ccmano
Ccmano's Avatar
That's interesting Jeff, are you saying the 63mm TB isn't really worthwhile unless there are major air flow enhancements to the heads?
Hans
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 10-30-2007   #4
blackjack
thats an interesting topic...i also heard that 58mm is big enough to feed a 350 cu.in,no matter what kind of mods you have...any real world results?...dyno comparo?
bj
91/1735
blackjack is offline   Reply With Quote
Old 10-30-2007   #5
Jeffvette
I would rather see somebody put the 300 bucks towards headers than to modify the TB.
Old 10-30-2007   #6
This is what Jeff told me 6 months unless you punch the block you are throwing your money away on this TB mod.
Old 10-31-2007   #7
bradslt5
How about if ya give it an upper -cut !!!!!!!!!!!!!!! Sorry couldnt help my self
Old 10-31-2007   #8
cuisinartvette
IMO if a 48mm TB will support a 502 CI BB the stock TB should be plenty for the LT5 even with plenty of porting. Sure, its comparing 2v to 4v but airflow is airflow.
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
