11-17-2016 | #1 |
Fuel Injector Flow Test
Does anyone know of a simple way to flow test fuel injectors? I'm chasing a misfire and would rather not drop $600 for a new set if I don't have to. I will do the OHM test as well.
11-18-2016 | #2 |
Re: Fuel Injector Flow Test
Just ohm them. they should be between 12.5-14ohms
11-18-2016 | #3 |
There is a full set of 94 injectors in the for sale section at a good price. 94-95's are fine and not bothered by the ethanol that troubles the 90-92 cars. I wouldn't hesitate using them.
Best of luck.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
11-18-2016 | #4 |
Thanks Frank. Have you ever heard of one testing at 17 ohms?
11-18-2016 | #5 |
probably need to look for consistency in ohms from inj to inj...unless you believe they are all bad.
11-18-2016 | #6 |
You're welcome. See Lees post above and look at his site for injector testing also. Marc Haibeck's site has a detailed way of testing all the injectors with the plenum on.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 Last edited by FU; 11-18-2016 at 02:53 PM. |
11-18-2016 | #7 |
Thanks Frank. I bought the injectors you put me on to, so hoping my problems will be solved. I also replaced the coils and am about to replace the fuel filter.
11-18-2016 | #8 |
Just tested them and they're all at 15.4 or very close.
