Old 10-24-2007   #11
ridalinLT5
Default Re: Clutch time
that was the problem it woreks good now. thanx to the guy on here who gave me some advic it worked!
ridalinLT5 is offline   Reply With Quote
Old 10-24-2007   #12
Buy a spung hub LT-1 Camaro clutch disc. It really helps in reducing the clatter from the ZF when in neutral. I bought mine from SLP. Not sure they offer one anymore tho.
Old 11-23-2007   #13
Bill B: Good guy report!!
Bill provided me with a new ZF and modified it with matched synchro springs and by opening up the oil galleries (to assure the reverse gear does not starve...again...a common problem with the ZFs, accoring to Bill).
I got the new transmission, all the work done and shipped for $2650 (ish). His web site has a ton of good info, not only on the ZF, but on the clutch maintenance and repair as well.
check it out -
http://www.zfdoc.com/faq.htm
P.
