Old 10-22-2016   #11
Default Re: VERY high idle
tps sensor correct?
Old 10-22-2016   #12
Blue Flame Restorations
Originally Posted by orthodoct View Post
Thanks, Brett. Very frustrating, thanks for your help. I have several patients from Byrdstown. I think that I will leave the password where we left it!
You are THE MAN!
Ty
Woohooo!!! I knew if we stayed at it, we'd get you up and going on the forum again.
Drive that Z like you stole it now!!!! Always here to help.
Brett!
Forum Administrator
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-22-2016   #13
orthodoct
Yes. Checked it first. Thanks!
orthodoct is offline   Reply With Quote
Old 10-22-2016   #14
orthodoct
Thanks again, Brett. Here for you, too.
Ty
Old 10-22-2016   #15
If this is a 92, has throttle cable ever been disconnected?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-22-2016   #16
orthodoct
Yes, from throttle body when I pulled plenum. Has mechanical ASR.
Old 10-22-2016   #17
Have u ever reset the cable length?
Old 10-22-2016   #18
I wonder if on a 92+ (w/ASR) if it is also possible to leave that throttle cable connected when pulling the plenum, and just flip the plenum over to lie on the edge of the wheel well (driver's side) like you can with the 90/91s? That would save the chance of messing anything up, PLUS facilitation the removal and installation by a few minutes - especially if it has to be readjusted afterwards...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-22-2016   #19
Paul,
That's nearly exactly what I do. Put a towel on the front tire, then flip plenum over w cable attached. Once back together, I do recheck the TPS voltage
Old 10-22-2016   #20
orthodoct
If I have to pull plenum again, I will do so but realize that when I pulled plenum, it was first time since new so sort of did a " frame off" restoration of everything. Besides, it ran great for 18 months until yesterday, sat 1 1/2 hours then ok for 40 mile trip home on two lane mountain road. Only residual problem is 2000 rpm idle where it was 1100 or so previously but that is by the tach in the car. I think that it is IAC, but could have a bit of leak past plenum secondary intake butterflies. Probably did too good a job cleaning them. Held up to a bright light with them closed and didn't see any air leakage, but didn't realize until reading on the forum that the grease that I cleaned off was SUPPOSED to be there. Was disappointed to read that. As well as that engine was built, the secondary butterflies on the plenum should be air tight. I can live with an idle of a thousand or so. Runs like a bat out of Hades! Thanks, guys. Will advise once I swap IAC. Got hit with "honey do's" this morning! Great bunch of folks on this forum; glad to be a part of you!
Ty
