Old 10-21-2016   #1
orthodoct
Default VERY high idle
Gentlemen:
New injectors, clutch, chip from Marc, plenum rebuild, headers, Corsa exhaust 18 months ago. Driving on country road today, passed a "turtle". Idle wouldn't drop below 4000. Had a heck of a time getting to destination! Checked everything roadside that I could, no change idle. Parked car for 1 1/2 hours, restarted, idle 2000 (normally 1100). Drove home, slow to return to idle with clutch in. Had similar problem when rebuilt and was IAC problem. Have a spare from Jerry. Before I tackle it, any other ideas of where to look? Cables are not stuck.
Thanks, my friends!
Ty
Crossville, TN
orthodoct is offline   Reply With Quote
Old 10-21-2016   #2
Default Re: VERY high idle
I would look for vacuum leak.
Old 10-21-2016   #3
orthodoct
Thanks, nothing obvious, but will check further.
Old 10-21-2016   #4
Is the car stock? NORMAL idle is 1100????
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-21-2016   #5
orthodoct
Marc Haibeck chip, new injectors from Jerry, Stainless Works ceramic coated headers with cats, Corsa stainless exhaust; everything else stock. 1992; have owned since new, stock idle has always been 1000 or so.
Thanks!
Old 10-21-2016   #6
Thanks!
Stock idle is set to 650.
Old 10-21-2016   #7
Stock motor with exhaust headers should idle between 650 to 700. I think you have a leak somewhere or IAC is hanging up. Or, could be TB binding somehow.
Old 10-21-2016   #8
orthodoct
Will swap IAC tomorrow AM. Just looked for vacuum leaks and no obvious suspects. TB operating smoothly throughout range. Replaced all hoses and meticulously rebuilt just about everything when I had the plenum off. Had it so clean that you could eat under there. IAC swap should drop idle. Will advise. IAC was problem previously. Got new replacement from Jerry and it fixed problem. Swapped old one back in and it worked so I left it in. Hindsight 20/20. Should have left replacement from Jerry in! Was a helluva ride today! Had to drive 20 miles in second gear with 4000 rpm idle to keep it below 70 and got behind every stinking log truck in Cumberland County! Go figure. Sitting in town traffic at red lights idling at 4000 rpm with that exhaust system was an experience. One of the red lights was 50 feet from the county courthouse! Good thing that I have operated on half the cops in the county! Was 30 miles from home, so had no choice. Thanks for your help!
Ty
Old 10-22-2016   #9
Blue Flame Restorations
Sounds like you got it fixed. My in-laws are in Clinton County, KY. Byrdstown TN.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-22-2016   #10
orthodoct
Thanks, Brett. Very frustrating, thanks for your help. I have several patients from Byrdstown. I think that I will leave the password where we left it!
You are THE MAN!
Ty
