#11 | ||
![]() Join Date: Mar 2014
#12 | |
Keep the Bend RED HOT and Bend Slowly with just a little pressure (do not force it). It will bend itself ![]() After modifying the 15/16 inch combination box wrench it is still very usable as a normal combination Box Wrench. I also have 8mm combination Box Wrenchs I did a little modifying on to reach those 8mm bolts on front of oil pan without raising engine. The normal Offset Box Wrench does not have a steep (Right angle) offset as you can achieve with an acetylene torch. ![]() Two more MCH-208 Alternator Pulleys will be installed tomorrow for more photos ![]() Just make sure the 5/16 inch Allen is FULLY installed in the center Alternator Shaft before you start cranking on the 15/16 inch Open End combination Modified Wrench (with cheater box wrench on end). It DOES take a lot of torque to loosen that 15/16 inch Nut holding the Alternator Pulley.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-21-2016 at 02:57 AM. |
#13 | |
#14 | |
Look for MCH 208 on Summit Racing MCH-208 or Ebay MCH-208 The MCH-208 is the same Diameter as the Stock Pulley. Actually the MCH-208 is just a tad larger diameter. Use a 1/2 inch Adapter on Socket Wrench to Unload the Belt Tensioner when removing/installing Pulleys. ![]() ![]() The Offset of the MCH-208 is identical to the Stock Pulley. The Stock Pulley has a removable Offset Collar. ![]() ![]() See All Aluminum Alternator Pulley
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-25-2016 at 12:54 PM. |
#15 |
I just might have to order that MCH-208 pulley after all and have it all ready for the replacement unit whenever it may be needed......
#16 | |
This Pulley can be installed without removing anything including the Serpentine Belt (except the Original Alternator Pulley). Remove the Alternator Pulley (takes 1 minute) and position NEW Alternator Pulley inside Serpentine Belt and lift up the Alternator Pulley and Serpentine Belt with Belt Tensioner compressed (Keep Serpentine Belt aligned with Belt Tensioner Pulley). Now just slip the Alternator Pulley onto the shaft (very easy to do and plenty of play) and tighten up the 15/16 inch Alternator Pulley Nut. ![]() Lastly......install the Aluminum Alternator Pulley Cap with the three Allen Head Bolts provided with just a little torque as they are threaded into Aluminum. The MCH-208 is the same Diameter as the Stock Pulley. Actually the MCH-208 is just a tad larger diameter. Use a 1/2 inch Adapter on Socket Wrench to Unload the Belt Tensioner when removing/installing Pulleys. ![]() ![]() The Offset of the MCH-208 is identical to the Stock Pulley. The Stock Pulley has a removable Offset Collar which is NOT used in the installation of the Aluminum Pulley. ![]() ![]() See All Aluminum Alternator Pulley
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-25-2016 at 01:09 PM. |
#17 | |
![]() Join Date: Aug 2006
#18 | |
![]() I am now curious that my 200 amp Alternator on my 95' might actually be 90' compatible in regard to the Alternator Pulley. If that be the case....I am all set with MCH-208. The Alternator I exchanged on my 95' I think did not have the separate spacer but did have a boss as part of the Pulley. Did your 94' Alternator Pulley have a boss as part of the Pulley? Is the Alternator cooling fan recessed just a bit where the separate spacer would sit?
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-25-2016 at 09:23 PM. |
#19 | |
#20 | |
I am now thinking All ZR-1 Alternator Fans have a small recessed (about 2 inches in diameter) around the shaft for which either a separate spacer or pulley with boss will function the same. The Boss is about half as thick as the separate spacer since the separate spacer fits into a recessed stock pulley. You can see the Boss and the Separate Spacer set the Pulley (Stock with recess and spacer or MCH-208 with Boss) the same distance from the fan recess around the shaft. ![]() ![]() In both cases the inside flange of the Alternator Pulley almost touches the fan surface at the outer diameter of the Alternator Pulley. ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-30-2016 at 10:48 PM. |
