10-20-2007 | #11 | |
Re: Normal Fuel Pressure
10-22-2007 | #12 | |
1991 ZR-1 #526 White/Red 1997 A4 Coupe [url]http://www.dd-designgroup.com/studio409/studio409.htm[/url] |
12-04-2007 | #13 | |
"vacume leak"
However, running OK when it warms up could mean that expansion is closing up the (gasket?) leak. But, it may be due to the fact that when it warms up and switches to "closed loop", the O2s sense the lean condition and the computer compensates by riching up the mix. This may well result in an increased idle speed in "closed loop"...or not...depending on method of idle control and/or where the leak is. Just a thought! P. |
12-04-2007 | #14 |
The ECM turned out to be the problem. Car runs like new now. Too bad the weather turned or I would still be driving it every day.
I put in the Fidanza flywheel a couple weekends ago and that turned out to be a great mod. The extra fun factor is worth the small amount of extra gear noise in my book. I also found my small transmission fluid leak and fixed it. Just when I get everything running right, winter shows up. Only about 12 weeks to go...
12-04-2007 | #15 | |
12-04-2007 | #16 |
Way to go there Dandy!!
Hey dere what part of WI are you in?
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
12-05-2007 | #17 | |
12-05-2007 | #18 | |
12-05-2007 | #19 | |
Sure no doubt on the way to BG each year right? Just Pm me b4 you make all the plans and we will be glad to have you stop by for an eyeball
