Old 10-16-2007   #1
kenthompson
kenthompson's Avatar
Default Clutch time
What are the opinions of the lords of Z as to clutch preference?
Stock,
Centerforce,
Spec,
Beck?
other?
The throwout bearing will need to be changed in mine, and I'm guessing that I will just change the clutch while I'm at it.
Oh, and add an aluminum flywheel and put the hurst shifter in at the same time.
kenthompson is offline   Reply With Quote
Old 10-16-2007   #2
bradslt5
Default Re: Clutch time
id get ahold of bill b the zfdoc and get what ever he recommends
Old 10-18-2007   #3
http://www.zr1netregistry.com/forum/...9&postcount=12
http://www.zr1netregistry.com/forum/...61&postcount=7
I AM A VERY HAPPY CUSTOMER OF CC NOW!!!
Old 10-18-2007   #4
Jeffvette
You don't need anything wild or exotic. There are guys with stroker motors running around on the stock set up.
You should still be able to get the stock LUK pressure plate assembly from either Bill B www.zfdoc.com or go and talk to Tom @ Carolina Clutch.
Old 10-19-2007   #5
kenthompson
I talked to Bill a day ago. He recommended going with Carolina Clutch.
Now all I need is a lift to get under the car with......
KT
Old 10-19-2007   #6
tf95ZR1
tf95ZR1's Avatar
KT
No problem, Ken. I used jack stands (up pretty high) and
removed my trans when I had to get a new one from Bill B.
Warning- the trans is surprisingly heavy. A Bit*h to lower,
and a Bit*h to maneuver to re-install. And be careful with
the pilot bearing/rear engine seal.
Old 10-19-2007   #7
ridalinLT5
hi. who is bill is he a tranny guy mine acts funny seomtimes the pedal feels funny ti only comes up a few inches. bradslt5 you are in california too i see.
ridalinLT5 is offline   Reply With Quote
Old 10-19-2007   #8
tf95ZR1
tf95ZR1's Avatar
Bill Boudreau knows and works on ZF trans/clutches, etc.
and is in AZ.
His website is:
http://www.zfdoc.com/
Old 10-19-2007   #9
bradslt5
ya where are you located? is yucca valley down by palm springs? are you a new zr1 owner too ?
Old 10-19-2007   #10
ridalinLT5
who is billb is he a real doctr. haha
yah im by 29 palms too
tf95zr1 i didnt see that link it looks like i have a hydraulic problem thanks. hope my transission isnt hurt
