Old 08-31-2016   #11
Default Re: Clutch and Rear Diff Upgrade Experience
Now that is a TOOL.......very interesting....I could have used that in several situations
Concur how many of us have tools just like this one that made life a hell of a lot easier and then never had a job to use it again lol. I have a drawer of a few of those.
Old 09-02-2016   #12
KJL
OMG!!! That tool is awesome! I bet it works great on teeth as well!
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 09-02-2016   #13
KJL
Goldcylon, I notice you have a Dewitts radiator. I installed one in my 96 LT4. It was when they first came out with the units that had an extra row. The thicker unit presented some challenges but when all was siad and done, I was happy I did it. Can really see the difference. How difficult was it to install in the ZR1?
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 09-02-2016   #14
Mystic ZR-1
Mystic ZR-1's Avatar
Anyone have the part number for the
correct DeWitt aluminum radiator for our cars?
Best place to buy?
Old 09-02-2016   #15
Best place to buy?
Model: 1139090M (Manual/double row)
If you order from Dewitt, it's $529.99 plus shipping. If you order the same from Summit Racing, it's $529.99 including shipping. I don't know why you get better price on Dewitt from Summit than you would from Dewitt.
KJL,
Only modification is to shave about 1/4" off internal fin separating primary and 2ndary fan (when you remove the shroud back panel, you will know what I mean) on the back panel of the radiator shroud.
Old 09-02-2016   #16
Or, grab the wedge with a vise grip and pull on it like there's no tomorrow. Or, this might work easier.
http://www.ebay.com/itm/2-Lb-Slide-H...QAAOSwU-pXsgRL
Oh! I used that same jig to pull the Secondary Port Throttle and bearings out of the heads when I eliminated my secondaries. So, spreading the cost of that 3mm bolt, 2 washers, and a 3mm hex nut over 8 SPTs and 3 transmission pulls, I estmate the cost was about $0.07/use.
Course, I coulda stuck my engine hoist in the cabin and used my vise grips and rigged some coat hanger wire between the hoist hook and the vise grips...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-02-2016   #17
Mystic ZR-1
Best place to buy?
Thanks!
I'll check out Summit.
After overheating (no leaks or steam) at Carlisle in 95+ degree heat and bumper to bumper traffic all the way back to the motel, radiator replacement is on the Winter to do list. 26 year old plastic radiator, it's time... Ran 6 hours home to CT without incident. In the meanwhile, blew out the air side with compressed air and flushed with Simple Green and garden hose. Lotsa dust and crap came out! Of course, removing the radiator and back flushing would be better, but that's enough for now. The car has never overheated before and the guage always indicates just shy of halfway.
Old 09-02-2016   #18
How hot did it get?
Old 09-02-2016   #19
Mystic ZR-1
It was so hot that....
Hot enough to turn on the warning lite.
Guage was in the high end of the scale, the numbers on the guage are there for looks...
95+ degrees, heavy bumper to bumper stop and go traffic with the AC on, can't blame the car...
Both fans running, (Marc's chip...) no steam or over flow, overflow tank level was fine.
Note: It's amazing how many overflow tanks you see empty...
Glad I put on new hoses this year...
Immediatly turned off AC and turned on the heater wide open @ max temp.
Pulled into a parking lot and let it cool for 45 minutes or so and waited for traffic to ease
before finishing short trip remaining to motel.
Later in the evening after cooling, started and ran fine with no issues.
Next morning told Marc all about it, he didn't get all excited just recommended that radiator needed a good external cleaning. He said not to worry about it, but keep an eye on it.. Ran fine not overheating on the way home to CT Saturday, still about 95 out...
Lotsa crap when I did my half baked flushing, good enough for the time being...
Old 09-02-2016   #20
Default Clutch and Rear Diff Upgrade Experience
For the 90-92 This link below is helpful in determining coolant temperature (deg C) unless you have 93-95 which will give you coolant temperature in deg F using the Gauges button on the Trip Monitor (Temp shown on Speedometer).
Just remember you are shooting for around 100 deg C (100 deg C is 212 deg F) on HOT days (100 deg F).
Using HVAC Display for Engine Coolant Temperature
