Old 08-14-2016   #41
tpepmeie
Default Re: 427 LT5 Build 2 underway
yes, it was Dom.
Old 08-14-2016   #42
ALZR1
Originally Posted by tpepmeie View Post
In case you guys want to follow along. The rotating assembly is together. My blog is updated with the latest steps. This will be the last update for awhile, as I need to get the cylinder heads ready and the cams timed.
http://pepmeierenginedevelopment.blogspot.com/
I like the Gas ports on the Pistons Todd
ALZR1 is offline   Reply With Quote
Old 08-15-2016   #43
OK Al, I'll bite: What are gas ports on the pistons? Those tiny little holes around the perimeters? And what exactly is their purpose? Inquiring minds want to know....-Bob
Old 08-15-2016   #44
Yes Bob.. I stumbled across this:
a gas port is a hole drilled from the piston deck (a vertical gas port) or from the top ring land (a horizontal gas port) to the rear of the top ring groove. The purpose of a gas port is to apply combustion pressure directly to the top ring, forcing the ring face firmly against the cylinder wall. The number, size, and location of gas ports vary with bore diameter, engine type, dome design, and the engine builder’s personal preferences.
Here is a link:
http://rehermorrison.com/tech-talk-2...-of-gas-ports/
Old 08-16-2016   #45
Here is a link:
Ahhh....thanks Jeff. I am enlightened! And the article itself was quite interesting. Right at the end it said: "When you cross the threshold of 1,000 horsepower, gas ports become essential for maximum performance." Certainly glad that Todd won't be held back any! --Bob
Old 08-16-2016   #46
Jagdpanzer
Jagdpanzer's Avatar
Looking good Todd.
The new rod bolts appear to have larger heads.
Did the block require further clearancing from before?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-16-2016   #47
tpepmeie
Looking good Todd.
No. A bit of an optical illusion. The shoulder is a little fatter, but the overall height is the same as the prior bolts. No clearancing required.
Old 08-17-2016   #48
Pete
Pete's Avatar
Todd did you buy sleeves from AES?
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-18-2016   #49
tpepmeie
Pete
No.
Old 08-19-2016   #50
Jagdpanzer
Jagdpanzer's Avatar
2" rods journals then?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
