![]() Join Date: Nov 2014
Curious...Just figured I would ask...Of course if a motor is out of its engine bay, head removal is relatively easy....Everything is right in front of you..
However, can the heads on the LT-5 be removed without taking out the entire engine? If so, is it more labor intensive than removing the entire motor? |
#2 | |
Remove the engine and I would say not really labor intensive to accomplish that. Lifting The LT5
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-04-2016 at 01:57 PM. |
![]() ![]() Join Date: Nov 2007
Adding to what Cliff said, a while back Marc Haibeck completed some head-work w/ the engine in place. The cam phasing was the trick - mirrors, live-action cameras... IIRC, he said it was more trouble to do it that way than it was to remove the entire engine to phase the cams. Pete agrees, as do other experts on the subject.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
