07-24-2016 | #31 |
Re: Euro Taillamps installed
Thanks Dom
QUOTE=XfireZ51;245505]Please no. I am sure everyone appreciates the contribution. I took the Brake Applied signal from the CHMSL line and connector. You can find it right behind the pillar courtesy lamp on the passenger side. Used a "scotch lock" to tap that line. Then ran a line along perimeter of hatch opening and drilled a small hole to snake that line through to rear. used silicone to seal it. Split that line into 2 and connected to each side of brake lamps. As u did, I was able to remove the white wire from the brake switch assembly without cutting it. I put some heat shrink over it. Anyone want to return to stock, it will be a very easy process to reconnect the lines.[/QUOTE]
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
07-24-2016 | #32 | |
I believe I've seen (in the 80's/90's) earlier European production when presented for VA safety inspection "failed" until RED was substituted. The secret is in here I'm sure!! http://www.ecfr.gov/cgi-bin/text-idx...e49.6.571_1108 Last edited by WVZR-1; 07-24-2016 at 01:04 PM. |
07-24-2016 | #33 |
Here's something else to think about. The only negative about running the Euro taillights is when the brake switch fails for the CHMSL you have no brakelights. It's already happens to mine and we all know how often the CHMSL fails because of a bad switch.
07-24-2016 | #34 |
I've got them on both ZR-1s, and love them. I do have a schematic somewhere if someone needs it. Note that there are 2 different versions of the light - some simply have "Guide" written on the lens, and another version has "GM"
and some additional raised markings. Rich had the only set of "GM"s I've ever seen. "GM" http://www.corvettemods.com/assets/i...cp-14399-1.jpg "Guide" http://i289.photobucket.com/albums/l...4/IMG_1214.jpg Regards, Mark
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
07-24-2016 | #35 |
Anybody have a set for sale?
07-24-2016 | #36 |
07-24-2016 | #37 |
07-24-2016 | #38 | |
Mark I could use a copy of the schematic for the lights.
Thanks, Nelson Quote:
07-24-2016 | #39 |
Doug I might have a set of the soild orange.
Nelson
07-25-2016 | #40 |
Last I looked MAMO said they were out of stock.
Mark, I'll check tomorrow, but pretty sure mine say GUIDE.
