Old 06-27-2016   #41
Default Re: Flat Plane Crank LT5
Sam is correct, the stroke is stock.
Old 06-27-2016   #42
mgbrv8
Thank you for the correction
Dave
Originally Posted by SAM/CH ZR-1 View Post
No Dave
The engine run with a stock 93 mm stroke.
Old 06-27-2016   #43
tpepmeie
Again, Great job by all involved. Did you dyno it before installation?
I am itching to do one of these. Although slightly different dimensions. Wish one of you ZR-1 brothers would win the Mega Millions tomorrow and pony up the cash for the ultimate LT5. I've got the crankshaft sourced and the cams to go with.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 06-28-2016   #44
SAM/CH ZR-1
For the next race season we plan to go with another bore x stroke configuration and increase the max. rpms up to 10'000.
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 06-28-2016   #45
Fully Vetted
Fully Vetted's Avatar
OMG…I'm going deaf just thinking about it.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 06-28-2016   #46
Just received word from Norbert Vornholt, "First race done. Second place. All doing well engine is running good. 750HP at 8800 Revs/min."
"Here two videos of that weekend."
https://youtu.be/JpMiTX_fqgs
https://youtu.be/XGrg98-mvnE
Old 06-28-2016   #47
Ooooo! That goes right to my bones!! WOW!!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-28-2016   #48
Excellent and simple explanation that is made even more clear by the video. --Bob
Originally Posted by ZRapid-1 View Post
Crossplane Crankshaft
Flat Plane Crankshaft
The Bottom Line
Crossplane Crankshaft Advantages: Smooth, vibration-free performance; distinctive American muscle car burble.
Crossplane Crankshaft Disadvantages: Heavier (harder to rev), requires larger crankcase.
Flat Plane Crankshaft Advantages: Lighter, more compact, more responsive (high-revving), better exhaust scavenging.
Flat Plane Crankshaft Disadvantages: Prone to vibration, lower torque levels.
Good video showing how the pistons move relative to each other:
https://www.youtube.com/watch?v=2AzrOPPZFzs
(Should have added exhaust sounds instead of music in the video.)
Old 06-28-2016   #49
spork2367
Such a cool build.
Old 06-28-2016   #50
That is some setup on the Opel. Driver is right on target.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
