Old 06-25-2016   #41
32valvesftw
Default Re: 430-435 CHP now.....What can I do to get 500-510 CHP?
In the big scheme of things you may actually save time by pulling the engine, as your access for porting would be much better and it will be easier to deal with the grinding dust and chips.
Old 06-25-2016   #42
Top Toy
Top Toy's Avatar
Head porting generally includes opening up both the intake and exhaust runners as well as unshrouding the valves in the combustion chamber, all of which require removal of the engine to get the heads off. If you're careful not to allow any metal bits to fall into the valve pockets, you can match the IH and head ports without removing the heads, but the benefit from that mod alone is pretty small.
'95 ZR-1, aqua/gray, #167
