Old 06-17-2016   #1
Johnny5
Default Power Antenna Question
Does anyone know where the power antenna wire is located in a 1991 ZR1? I want to install a switch i bought to shut off the power bc i dont use the radio and i do not want the antenna going up and down constantly
Johnny5 is offline   Reply With Quote
Old 06-17-2016   #2
Blue (I think) wire at the CDM box. Pass side of dash.. Or back behind the package cover on the driver side
Old 06-17-2016   #3
Default Re: Power Antenna Question
I thought the antennae only comes up when radio is ON?
Old 06-17-2016   #4
And when you play CD and if you are running navigation head unit which stays on all the time.
I installed a switch and keeps my antenna down. Around town, even with the antenna retracted, have no issue receiving FM and HD FM signal.
Old 06-17-2016   #5
Vetman
Vetman's Avatar
Marc installed one for me under the carpet behind the driver seat. Saves the up and down big time.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is online now   Reply With Quote
Old 06-17-2016   #6
My reception was terrible.. I replaced the antenna and it got better.. Ground strap is next
Old 06-18-2016   #7
Johnny5
where is the power wire that you splice a switch into?
Old 06-18-2016   #8
You have an aftermarket Pioneer nav unit? If so, look at installation electrical schematic.
Old 06-18-2016   #9
on a 1990-1 passenger side there is a CDM. The main radio module, that is where. I don't have pictures though
Old 06-18-2016   #10
secondchance...
What unit do you have in you car?
