Old 06-10-2016   #11
Default Re: Hi Idle
Originally Posted by Billy Mild View Post
I'm talking about a vacuum hose, not a throttlebody issue. If he used a piece of cardboard to cover the airhorn and the idle was still high that points to a vacuum leak AFTER the throttle blades.
And I was simply pointing out that throttle plate openings are, technically speaking, vacuum leaks. IACs create regulated vacuum leaks also.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-14-2016   #12
scottskill
Default Re: Hi Idle
Accomplished the task of isolating each vacuum line independently and found several joint connection blocks leaking. Repaired the connections with silicone, no leaks noted. Reassembled intake runs like a LT5 should with 19 inches of vacuum! Thanks guys for the help!
scottskill is offline   Reply With Quote
Old 06-14-2016   #13
Billy Mild
Default Re: Hi Idle
Did you replace the rubber connections with Silicone hose?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 06-14-2016   #14
scottskill
Default Re: Hi Idle
No, applied silicone to the hard line after cleaning then inserted to the end coupling let it semi cure reinstalled.
Sent from my SM-G925P using ZR-1 Net Registry mobile app
