![]() Join Date: May 2011
Both the motors on my lumbar support air pumps run but the bladders don't inflate, any ideas?
![]() Join Date: Apr 2004
Take them out and replace the rubber in the pump end, I used rubber from a bike inner tube cut it to size works great!
Link http://www.zr1.net/forum/showpost.ph...93&postcount=1
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 06-01-2016 at 04:09 PM. |
![]() Join Date: Jan 2010
take them apart and replace the diaphragms.
you can make new diaphragms out of a rubber glove or an old inner tube. old inner tubes come in handy for lots of things! new one's are probably available, someone here may know where? Last edited by Mystic ZR-1; 06-01-2016 at 03:59 PM. Reason: ... |
Thanks, I'll give it a try!
![]() Join Date: Feb 2014
It's also quite likely that the bladders themselves are toast. They're plastic and degrade over the years. When I had the seat covers on my 87 replaced a couple years back, the upholsterer described the original bladders as "swiss cheese". If this is the case, it's unfortunate, because if you try to replace them, you end up ruining at least the seat foam and probably the seat covers too. The motors on my Z worked fine but the bladders wouldn't inflate, and I assumed that was likely the issue. Good luck.
#6 | |
![]() Join Date: Jan 2015
When I had a seat apart last year I noticed one of the small plastic manifolds (where the hoses connect to) had a broken-off nipple. So, even if the pumps and bladders are fine, the compressed air leaks out. It looked like an easy fix. Just haven't gotten around to it yet. Good luck. Maybe take pics of what you find? Thanks.
I have to agree,the bladders fall apart with age. The bladders in my car with 7000 miles were in pieces and some pieces turned to powder.
#10 |
![]() Join Date: Feb 2012
That would be Bladder Powder?
