![]() ![]() Join Date: Nov 2007
Got home from MR4 and BG and parked the car. It sat there in the garage for a week before I had time to wash and clean it up.
So, I pull out of the garage drive 30 yards or so to my wash area. While washing the A-molds, I notice the RF tire pressure appears to be a little low. But, by the time I get done with the drying/spritzing/polishing a few minutes later, the tire is almost flat. After re-inflating and inspecting the tire, I find what looks at first like a cut in the sidewall extending from the rim edge half way across the sidewall. And, it is leaking bad enough to feel a breeze on the back of my hand when passed near the "cut". However, the grass was just mowed (short) and there is nothing I could find that could cut a sidewall that way. And, there was no bruising around the damage to indicate something had punctured the sidewall. (Not a mark on the rim either, tho the split runs right up to the rim!) I've seen tire damage and repaired hundreds of flats while working at a service station (back before gas stations turned into mini-marts). But, this is strange... ![]()
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
![]() Join Date: Feb 2012
Box Cutter?
How old are the tires? What make? I've seen tires do weird things..... I've notice using lots or any tire shine, tends to wear out the rubber faster. Drys it out. Do you remember, maybe that tire going off the road, or pothole on the MR4 run?
![]() Join Date: Feb 2011
I ran over some sheet metal from a heater duct in Los Angeles on interstate 5 once...it was already smashed flat from some previous vehicles, but I tried to straddle it down the center of my Z28...
the upturned corner just cut the inside part of the sidewall and pretty much took out that Goodyear Gatorback. I didn't hardly feel anything, but a mile down the road it was flop flop flop and hard to drive straight. |
![]() Join Date: Jan 2015
Paul, the picture isn't displaying properly. :-)
![]() Join Date: Jun 2015
You probably hit something on the way home and it just let go when you moved it. Be glad it let go when it did.
![]() Join Date: Apr 2007
A head scratcher...
Paul, how big are the cats where you live?
![]() Join Date: Sep 2010
Sounds like the short drive from the garage to washing area flexed the tire enough to cause the cut to finally start leaking.
1. If it's deliberate vandalism, check your other tires for damage. 2. Could be caused by road debris. Recent damage now failing. 3. How old are the tires? Older damage now failing? |
#10 | |
![]() Join Date: Apr 2013
How old is the tire? Could have cracked on it's own I guess.. Kinda is a stumper though. I too used to work in a service station and fixed tires can't remember seeing what you described..
[LEFT][SIGPIC][/SIGPIC][/LEFT] [CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER] |
